Threads: 17
If you replace the chain then also replace the pad's while you are there .
It is a one piece chain and they tend to wear , the pads get old and brittle due to age . And are not that expensive .
The camshafts have to come out either way .
volvo V70D5 Black
Porsche 968 amethyst
Threads: 8
Thats the plan. Thanks for the advice!
'94 Cabriolet, Iris Blue /Classic Grey
Threads: 17
To set the cam timing you need to remove valve cover .
When replacing the belt your timing could be off , to get it a 100% you need to retime the camshaft .
volvo V70D5 Black
