About eight months ago, a new issue arose. I drove the car to Thunderhill Raceway and parked. I am a driver coach and do not track the car except for coach demo rides lasting a total of 20 minutes. The odometer shows 108k. A couple of hours after arriving, I started the car and heard a rattling noise in the engine compartment which disappeared in less than 10 seconds. Eight months later and at least 3000 miles, I took the car in for service. It was determined that the cam chain adjuster was worn along the cam chain. The engine performs great but it is just a matter of time before calamity strikes. Teeth on the cam gears can break off and then the chain disengages from the cams in some way. Then all kinds of engine damage can occur.
Based upon a reference from Bob Frith, I contacted Porsche North Scottsdale. Jamie Waldron
jwaldron@penskeautomotive.com responded with cost and availability details. The cam chain adjuster assembly is a remanufactured unit with a core charge of $1022.01. That means PORSCHE really wants your old one and to them your old unit is worth $1022.01. Porsche North Scottsdale uses FedEx ground and delivery to a business is always less than residential. The cost of the adjuster is $1505.01 unless the core is not returned. Then the cost is $2527.02 for the adjuster. Since the adjuster is being sold out-of-state (I live in CA and the dealer is in AZ) there is also no tax.
The parts are ordered and will take about three weeks to arrive from Germany. Now I am researching where to buy the intake and exhaust cams. So far the possibilities are RS Barn, Web Camshaft and 944online. Prices differ with the lowest cost for each remanufactured cam being $395 plus a core charge if your cams are not returned. New cams are $800 each. All I can say is check the adjuster pads and monitor the condition of the cam chain. The teeth on the cam change from being round at the tip of each tooth on the cam gear to being more of a peak for each tooth. As the teeth wear, breakage can happen. Around 100k miles, it is usually a maintenance issue meaning the cam adjuster, chain and cams require replacement. Change the cam pads while you are in there. The lower pad wears 2x the top pad so you really can't see how bad it is.
