Threads: 59
Just went through this with mine. With the engine bay pans in place underneath, it is often hard to determine where the leak is coming from. the coolant drips down on the pan and accumulates there until the pan overflows, so leak then appears on the ground, but perhaps not in relation to the source.
With my recent experience, there was fluid on the ground everytime the car was shut down and the engine cooled of. Common sources of leaks under these circumstances include, loose hose clamps, leaking water pump, leaking radiator drain, cracked coolant reservoir. The easiest way to locate the problem, in my experience is to have the coolant system pressurized. When I did this with my car recently, I discovered a crack at the nipple that the coolant hose to the reservoir is connected to and a leaking water pump. I installed a new pump, and a new coolant reservoir, tightened all of the hose clamps and pressure tested it again. I still have a very slight seep, not even a true leak, on the radiator tank. I'll watch it, I don't think it is significant enough of a leak to require a radiator replacement.
There are two other possibilities, the heater control valve and the heater core. Most of the time when the heater core starts to leak you will find coolant in the passengers seat foot well, but not always. When my heater core failed last year the bulk of the coolant leaked outside of the car.
As long as there is sufficient coolant in the car to fill the radiator and the water galleries in the engine the operating temperature will remain normal.
Chris Vais
2008 Audi A5 Brilliant Black
Threads: 3
Check the pressure cap, if it fails the car will dump coolant after shutdown.
Joel Frahm
1987 928S4 Diamondblau/Blue
Threads: 25
Hi all,
My car has started urinating coolant, too. I had a good look under and it's not from the <acronym title='heater control valve'>HCV</acronym>, Radiator, or any hoses. This is a bummer cause I just did the belts and seals this February, and I'm feeling it's the water pump gasket (this was done 3 years ago with the belts). I took the upper guard off and everything was bone dry where I could see the pump. It's leaking in two spots and losing about 4-8 oz after driving the car each time. I found coolant back on my steering rack.. kinda odd, can the waterpump gasket leak this much? What about the heater core? Is there anything else that could leak in that area? Maybe I need to take the lower guard off to get a good look at the water pump. The car is my DD, but luckily I work 4 miles from my house, so I can top her off when needed.
Thanks,
-Rene
94 M030 968 Guards Red/ Beige ~64k miles
2006 F-150 King Ranch 4x4
(This post was last modified: 10-22-2012, 10:04 PM by
Nenehubert.)
