11-19-2013, 06:06 AM
Hi Team
I was driving the 968 after six months storage. Did the warm up, Fluid checks etc etc and was 10 kms into my drive when the abs light appeared and the speedo stopped working...... Problem 1. After reading the forum I will investigate the relay for the speedo first of all.
I continued to my destination parked the car and after a few hours I started and drove straight home. (total trip 40 kilometers)
As i was driving home I went to manual mode and the transmission would not change gear at all, The shifter was moving freely. as i kept driving i went in and out of the gate to the manual mode a few times to see if it would work but it didn't help or fix the problem. Then the unthinkable happened as i tried again the shifter jammed in bettween the gate and i was stuck in drive. I made it home but the car is in the middle of the driveway as i cant reverse into the garage. And i cannot start the car because It is stuck in gear.
I jacked the car up and it is on stands now but I cannot find any visual clues. Probably not looking in the right places.
I have tried to find as much information as possible before posting however like all questions i wanted to be specific to my symptoms.
Best Regards
Thanks in Advance for any help!
Best Regards
