10-27-2011, 04:31 PM
Hi all.
I have the above problem when the car is driven hard i almost get a little vibration through the pedals also it revs through the rev range fine but feels a little coarse.
Also when trhe car is at idle and i stamp on the accelerator i get a little miss before the engine revs smoothly, the car vibrates slightly before the rev needle flies up.
Dont know if these two are linked i thought maybe the balance belt may have jumped a tooth as the roughness may be coming from the engine harmonics not being in sync.
I do have a promax chip and have the drilled airbox as per flash's instructions, the car is certainly louder with the air box mod could this cause the vibration when the car is revved hard??
The car has had new plugs rotor arms dizzy cap. I have read a few post regarding DME relay not sure what dme stands for could it be this??
Any help as usual is warmly received and with the help i got from you guys last time regarding floaty steering the 968 forum is now stuff of legend amongst my "car friend"
thanks again
thanks again
