Three small questions...
On the attached picture, you'll see three things circled.
Question 1 - Gas cap doesn't seem to be flush, how do I fix this?
Question 2 - Area around top of the hatch, see the delamination? How can I fix that?
Question 3 - The front right corner of the sunroof doesn't sit all the way down flush. It did when I first got it, but after I took the sunroof off for cleaning, I haven't been able to get it to sit flush again. Anyone know what's up?
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Gas cap - The mount is a bit flimsy and can be adjusted a little, but I have never seen one so indented.
Sunroof - Try installing again and ensure that the front is properly seated from the begining of closure. These can be tricky. Often the problem you are seeing occurs after a new sunroof seal is installed. It can take months to settle down - or never seat exactly flush.
Both of these problems make me wonder about the surprisingly good condition of the paint on a car with over 100k. Has this car been in an accident or had a new paint job to your knowledge? It seems to have very little wear or rock chips. Having asked, this could also be a function of good wax, paint care, and a lot of highway luck.
Delamination - The curse of the 944/968 series. Do a search here and also on the Rennlist 924/944/968 forum as I seem to recall someone posting a repair procedure. Was not an easy fix. The rear hatch glass is scary expensive - replacement after an accident in a 944 can easily total the car due to cost. From the photo yours does not look all that bad for the mileage.
Ralph
'77 911S (RIP)
Gas Cap - I'll try and adjust it.
Sunroof - I'll do what you said.
On the paint - Originally it was bought in Houston, spent two years there and then came to San Antonio and was traded in on a new Jaguar. Second owner bought it from there and owned it until Jan of this year. He was a phd psychologist and very anal retentive according to the shop that worked on it. They said that it was never in a wreck but that it was repainted, by whom they don't know. That owner is now overseas so I can't find out exactly.
I'm going to replace the aero skirt moulding and door latch moulding this weekend, and try to fix the gas cap problem. I'm also going to throw in a noise suppresor for the radio.
Once that's done, nothing left to do but drive it and enjoy it!
Michael Sorbera
2002 VW Beetle TDI
[quote name='RPM' date='May 4 2005, 12:26 PM']Delamination - The curse of the 944/968 series. Do a search here and also on the Rennlist 924/944/968 forum as I seem to recall someone posting a repair procedure. Was not an easy fix. The rear hatch glass is scary expensive - replacement after an accident in a 944 can easily total the car due to cost. From the photo yours does not look all that bad for the mileage.
[right][post="4218"]<{POST_SNAPBACK}>[/post][/right][/quote]
I had a guy who worked at a detailing shop tell me that I should take a razor blade to it. I have thought about doing it, but have been reluctant. It just bothers me that the rest of my exterior looks virtually brand new, but when one looks at the delamination, it really betrays the age. What do you think, RPM, about the possibility of using a razor blade to scrape off that offending mess?
Just an idea, but...
Too bad you can't just find a vinyl trim to "trim" one inch around the outside on the glass. It is very water and heat resistant. Could always make a stencil and take it to one of those custom vinyl sticker shops (do it in 4 pieces). On a black car, you wouldn't even see it with black vinyl and it would cover the delamination.
Rustech
[quote name='sasilverbullet' date='May 4 2005, 10:49 AM']Once that's done, nothing left to do but drive it and enjoy it!
[right][post="4220"]<{POST_SNAPBACK}>[/post][/right][/quote]
Yah,.....Uh huh. He's already got the bug. <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" />
Silver BLT
noise suppressor? what noise is it making? a buzzing or staticy sound is generally a ground issue - a whine is alternator - both are fixable without a "suppressor", which rarely work without degradation of the audio quality
It's ignition noise that increases with engine speed. It only shows up in AM. I bought a 20amp noise filter at Pep Boys that will go in-line on the radio's power wire. That should fix that.
And I've also got to re-terminate the end of the antenna cable
I might get to this tonight, more like this weekend though...
Michael Sorbera
2002 VW Beetle TDI
Last Post by au968
02-19-2007, 07:07 AM
Last Post by Darryl
06-27-2006, 08:01 PM
Last Post by 94SilverCab
03-20-2006, 06:44 PM
