Alright, so I just did a little bit of observation. Here's what happened:
-I turned on the car, waited for it to heat up.
-While waiting, I checked the radiator tubes with an infrared temp sensor, and measured the top tube heat up to 170 F while the lower was staying at 75 F.
-As the gauge reached the 8 o'clock tick, the lower tube heated up fairly rapidly to 140. The fans did not come on.
-I drove the car around the block to heat it up and get the fans blowing and also to see if i could get it to warm up above the 9 o'clock mark.
-When driving the gauge stayed right at the 8 o'clock mark, but when I stopped and idled back at my house, it slowly rose to about the 9:30 position. Only when it got this hot did the fans finally come on.
So, the Thermostat seems to work, it cools the engine while the car is moving, but the fans are coming on "late"
Do the temp sensors go bad like this, causing the sensor to switch late?
If so, Flash, your non-definitive answer is actually a definitive answer, so you're right, which happens all too often in my opinion [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
So I'll try replacing it.
Phil
