temp gauge
Hi all, Just got the car out of winter storage and the temp gauge needle keeps getting stuck way high. The fans seems to be cycling on an off normally but the gauge reads full hot. It has happened twice now and each time the needle eventually drops like a rock to normal -last time i pulled over and checked- the fans weren't even on -then i turned the car on and off twice and the needle dropped in free fall. Any help is appreciated- Brett
Sounds like a sticky thermostat. Or perhaps it's an electrical issue either with a poor ground or questionable temp sensor.
I'd verify the temp before driving too far - hopefully it's not getting that hot...
needle is dropping too fast- even a stuck thermo when breaking free wouldnt cause a free fall i'm talking a split second drop from top to actual temp
Brett -
Erratic gauge indcations sometimes indicate failure of the gauge itself. Next time the needle fluctuates to the high end of the scale, tap on the face of the instrument cluster at a spot adjacent to the temp gauge. If the needle drops back down, it's likely the gauge is at fault. These gauges can usually be repaired.
Joe
1995 968 Coupe
Guards Red/Black
I had the same issue and I was afraid that I was overheating and would damage the engine. It turned out to be a bad gauge. I got a unit from a bone yard.
The gauge acted normal and I felt much better,
Brian
If it is the guage- where can i get it repaired?
Brett -
Palo Alto Speedometer (www.paspeedo.com) and North Hollywood Speedometer (www.nhspeedometer.com) are both here on the west coast; either should be able to repair your gauge. Good luck.
Joe
1995 968 Coupe
Guards Red/Black
09-15-2012, 06:39 PM
Last Post by 94SilverCab
01-26-2011, 01:35 PM
Last Post by 968TDG
11-04-2009, 01:51 PM
Last Post by Kim
07-05-2009, 03:39 PM
06-18-2009, 08:23 PM
