24402. (a) Any motor vehicle may be equipped with not to exceed two
auxiliary driving lamps mounted on the front at a height of not less
than 16 inches nor more than 42 inches. Driving lamps are lamps
designed for supplementing the upper beam from headlamps and may not
be lighted with the lower beam.
(b) Any motor vehicle may be equipped with not to exceed two
auxiliary passing lamps mounted on the front at a height of not less
than 24 inches nor more than 42 inches. Passing lamps are lamps
designed for supplementing the lower beam from headlamps and may also
be lighted with the upper beam.
The "flasher" light which goes on with the high beams is here defined as "driving lamps".
The "fog light" falls in the category the code calls by the same name.
But actually the "fog light" as a fog light is impractical because the beam is focused to the lower
portion of the road as Bulti pointed out. The amber light will cut through the fog, the white will glare and
in heavy fog will appear as a wall of white with the lower portion of the road illuminated in yellow.
And that would be strange indeed.
In practice it would fulfill the function of a passing light except for the height restriction which is 24"
I didn't put that smiley face in there... so gremlins are at work.
