10-30-2005, 02:00 PM
Ok this whaT I have and plan to do...
Door Speakers Infinity Kappa 52.5i (5.25") RMS 55w Frequency Resp 55Hz - 21KHz
Rear Speakers Infinity Kappa 652.5I (6.75")RSM 75W Frequency Resp 45Hz - 21KHz
Subwoofer for back right cubby Image Dynamics (8")
Current Head unit is a Rockford Fosegate RFX8330 40Wx4 channel
I plan on making a sealed Sub box to fit the rear cubby with its own dedicated amp.
and bridging the sub.
So my questions start with
Crossover Questions?
The infinities come with their own crossovers
I don't know if the rear speakers currently have crossover installed, but I believe the fronts do - so should I go with the porsche crossovers or the new Infinity's?
Or more complicated - with fronts having the split for the mids and the tweeter - could I splice into the wires before the porsche crossover and add the infinity to run directly to to them but continue the original wire the p-crossover for the tweeters? if that makes sense.
Caps/Bass blockers
With the Sub I should put some caps on the infinity's - right? So what and where would I install them? before the crossovers?
More Power?
I want to see how it sounds when I get it together - but any thoughts on needing a separate amp for the speakers? and if so How powerful
Thanks Sam
Caps/Bass blockers
More Power?
Thanks Sam
