Threads: 35
[ATTACHMENT NOT FOUND]Okay, getting ready to pop in a Bilstein Escort Cup Coilover Suspension for Auto-X and occassional DE events... some smooth road driving but < 500 miles per year on the highways with J Q Public... They already nailed me once and almost got me a second time in one month! Lucky I was driving old Red, the GMC SUV that takes a lickin' and keeps on truckin'!!! Both times female drivers... one on a cell phone and the other with no headlights and was "Looking for the switch"... Go figure!
Well, back to subject at hand... Photo attached of the Bilstein Coilover setup for my 968 Coupe... And the question of the moment... what is the recommended Spring Rate for both fronts and rears... the package came with 500 + 40 (helpers) in/lb fronts, and 400 in/lb rears, as recommended by a "Shall Remain Nameless To Protect The (maybe) Innocent" noted race shop, but that doesn't mean I have to use 'em! Springs are cheap to try different combos, so give it your best shot! I bet someone has the "Hot Ticket" out there!
Oh, 2.25" Perches front and back, so unless I decide to switch those out, I need to stay with that parameter... And, I don't intend to pull the Torsion Bars, so the rear Coilovers have to "Play Nice" with the bars...
But, there s/b ample Spring choices for the rears... even with the bars still in place...
(This post was last modified: 01-17-2007, 04:34 PM by
Darth Vadar.)
Threads: 35
Hey, thanks very much, Eric!
Yes, keeping the torsion bars is a pain in some ways, but, I read somewhere that Porsche even went back to using them in their Cup Cars, after trying to run with just Coilovers...
I could always soften the front by putting the 400's up there, and buying some 250's for the rear...
Then index the bars, etc.
I have some time and am close to the Tire Rack South Bend, so will ask them if I can do some testing on their skid pad ... watching a customer remove rubber from a set of tires they just sold him should make them smile! Our PCA Region does a lot of Auto-x's at the Tire Rack, so hopefully they will let me do a few laps!!!
Threads: 35
Not a bad idea! The Tire Rack is normally very supportive of PCA activities, so they might go for a 968 "Get Together"...
They are literally right on the I-80/90 Indiana Toll Road, halfway between Chicago and the Ohio border... easy to find and lots of motels and restaurants close by...
Tire Rack has a nice skid pad, and also a short track for Auto-X events; they are usually booked most weekends during the summer, but I can see what they have open... I won't be back there until Spring, so everyone sit tight and we will see what develops!
Threads: 35
Well, sounds like the 500 (+40's) front and the 400's rear will get me "In the Ballpark", and then I will just have to try different rear Spring setups and torsion bar positions to see what the car likes best!
Question: If I run my 8" Eibach 500's + 40 in/lb "Tenders" with my Racers Edge Spring Perches and Camber Plates, how much will that setup lower the front end? One inch? 1.5 inches?
Almost forgot... I am planning on implementing the M030 Sway bars, front and rear... will those work well with the Bilstein Coilovers??? Or....?
(This post was last modified: 01-20-2007, 05:00 PM by
Darth Vadar.)
Threads: 35
Threads: 35
Excellent info!!! I am going to start with 540 front and 350 plus stock T bars rear, and see what the old girl feels like with those...Look Out, Tire Rack...coming your way!!! Warm up the ol' skid pad...
I like your analogy "Danced Like A Donkey"! Somehow, I can sort of imagine that! I assume you reindexed the T bars to get your ride height where you wanted it?
What length Springs? 8 inchers?
Threads: 22
What are the advantages of keeping the torsions bars vs removing them? (I understand the difference in necessary spring rates with or without the t bar)
'93 Grand Prix White M030 6spd Coupe
Threads: 35
[quote name='RoadRacer' post='30157' date='Jan 24 2007, 02:17 PM']What are the advantages of keeping the torsions bars vs removing them? (I understand the difference in necessary spring rates with or without the t bar)[/quote]
Well, from what I have gathered, Porsche never intended the 968's to run w/o the T bars, and the stock rear shock mounting points are simply not up to the task of supporting the entire suspension load with Coilovers only. Of course, for the full out caged racers, there are complete rear suspension replacement setups, BUT, that is not what most of us are going for... and, in fact, the Porsche factory racers kept the T Bars and just added on the appropriate Coilovers, so that would seem the best way to go for a street / track combo car.
The challenge is to get the right combo of coil springs, shocks and ride height with the T Bars still in place... pull the T Bars, and you only have to deal with 2 variables, vs 3...
That said, there are plenty of folks (like Pete at RSBarn) who have gone thru the process of elimination and sorted the variables sufficiently, that the rest of us can get pretty close to "Right On" out of the box... depending of course on where we are starting from! But that is what keeps it interesting...
