on the presumption that you need to change those bushings, yes
those particular bushings are not known for failure, and unless the car is going to be tracked, or you are increasing springs rates and such, or you are as sick as i am, the benefits of hard bushings in that location are minimal
i was looking to lower the rear of the car beyond what the eccentrics could do, and i wanted to increase rear spring rate - that meant either reindexing the torsion bars and/or replacing them, or going coilover and deleting them
the only reason i went to the polybronze was that the delrin torsion tube bushings i had in there made noise - i would not have likely changed from the rubber at all, if i had kept torsion bars in there - without the torsion bars, i had no option - the rubber could not support the control arm all by iself, without the inner tie point of the end of the torsion bar
seriously, it is a huge amount of work to change this particular bushing, with it only making a difference in the most extreme situations, or if you are deleting torsion bars altogether
on the other hand, the elephant racing rear lower control arm bushings do make a significant difference in feel and control, at the expense of a bit more noise and harshness, and are pretty easy to install
just because i did something, is not a reason for somebody else to do something - it's really about, how you intend to use the car, what you can tolerate, to some extent how much power you are outputting, and very much what the budget is like
for a street car, that is not looking to increase rear spring rates, or be lowered a lot, i think there are better places to spend the time and money that to replace a part that does not generally fail, cause problems, or has a minimal return in improvement when changed - i love the parts, but i had specific reasons that demanded them
