well, i guess we need to divert a bit
beachboy, i hear what you are saying - let's see if i can clarify what i was trying to say, because i think i left a little too much to misinterpretation
here's what happens when you have too big of an amp - the signal to noise ratio goes down - you end up with louder sound, but not cleaner - to properly set up a system, you use a meter, find the spl near the max rated speaker handling, and then adjust the gain on an amp to match - if the amp is too big, you end up not getting into the optimal range for the amp, and end up with white noise - this is long before you blow anything up - this makes the high end very edgy and adds sibilance very quickly
if the amp is too small, you distort, as the amp is working harder than it can in its own THD
it's really about matching, but, what i was talking about is that, rather than stick in an amp with 50w/ch to drive speakers that can only handle 14, i'd stay with the deck power - now, if you could find an amp that is only slightly over the speaker rating, then that's great - i haven't had a lot of luck finding one lately though - i'm on the hunt now for a small sized 4x25
and i totally agree on the sub - i would not expect or try to get the small speakers in this car to reproduce anything low - the best i've seen for the front is 60 and that requires an air tight chamber - as it is, you'll be lucky to get an accurate 80hz out of them - the rears aren't much better, still require a sealed chamber, and won't even then go below 60hz - no bottom end going on there, and only distortion if you try, regardless of power
as a test, i hooked up a 200W amp to a 4x6 that is claimed to go to 45hz - the analyzer said it was only accurately reproducing about 70hz - everything below that was mush
the mistake most people make is to try to get bottom end out of deck power, into small speakers, and they end up doing exactly what you are talking about - distorting - more power won't really help here though - if the speaker can't go that low, as is the case of anything we can get to go up front, then it doesn't matter how much power you have, it's just going to distort, and with too much power, rip loose a voice coil
if it's distorting down low, better to eq it out or use some form of crossover - power is not really the answer there
this is why the parametric is so important - in an arena i use third octave eqs, but in a car i prefer a parametric - (however, i am installing third octave eqs in my yukon) - in my studio rig i have third octaves - in my home system i have both
bass and treble knobs only just won't get you there
