RS Barn airbox shroud
It looks the part and I assume that it does the job too but it doesn't state on the site if any hacking is required to the sheet metal (although I assume it does since the air has to enter somewhere). Has anyone tried this piece and where there any noticeable gains?
http://www.rsbarn.com/airbox-shroud.html
I have one that I ordered when I did my airbox mod. Once I got in there, though, I realized that the plastic cover, with the glove/rag compartment, does roughly the same thing, looks better, and has the cool little "hidden" compartment. As a result, I decided not to use the shroud. If you're interested, I'd sell you mine for $75 - virtually brand new. By the way, it fits right in, no hacking, no mods required.
Bill
'93 Horizon Blue Metallic Cab
'58 Triumph TR3A (sold)
'06 Lexus RX400h Hybrid
Lots of guitars
Thanks but I got a good deal from Pete along with some other stuff.
I don't have the trimming that the coupe has as Porsche apparently decided it was too heavy to go in a CS so I'm hoping that it'll do some good in the looks department at least. Pete says the intake air temps dropped some 40 degrees (Fahrenheit I guess) and that's enough to make a difference.
Last Post by Chris Vais
04-23-2021, 03:29 PM
Last Post by Kunz
05-06-2015, 09:55 AM
Last Post by pazzer
06-19-2008, 06:00 AM
Last Post by Renalicious
02-19-2007, 02:52 AM
Last Post by schwarz968
08-05-2005, 11:52 PM
