Radio Help Needed
I decided to tackle installing a new radio on my 93 968. the prev. owner put in a sony that had poor reception and no AM at all. My guess is that the antenna boost was not installed.
I found the little red/black antenna boost wire, but I don't know where to put it in my new radio harness? Also, the antenna wire has another little wire in the insulation. I think the prev. owner changed the antenna plug to fit the Sony and installed that little black wire in the auto antenna pin.
Where should I put the antenna boost wire (the red and black one) using the new Panasonic harness?
The Panasonic harness has:
Power Lead +12v to ACC power
Ground lead
Battery lead
and External Ammp Control Lead also called the Motor Antenna Relay Control Lead
and the speaker leads
Any help appreciated
I have no booster and very good reception. Are you in/near a city?
If the booster is powered, and the red/black wire went to the booster, red/black wire was most likely to switched power. Not sure though....
Also, i have the mast antenna.
actually, if your antenna system is stock, you have a booster up in the roof area
pretty sure the red/black goes to the remote turn on lead (typically blue) - i seem to be having a hard time remembering though -senility setting in
Yes, both of the above replies are corret...antennae amp/booster gets it's power from a switched lead...ie, only on when the radio is on. It is indeed the red/black smaller guage wire.
- Darryl
Just a note: I removed the booster and wiring from rear roof location and placed it in the trash. New radio and new antenna wire and new antenna and NO reception problems.
yeah - if you replaced the entire rf cable, then it would work fine - there is no interruption like there is with the booster - i have often wondered why they went the route of the booster rather than just a better cable and antenna - it's like they went out of their way to reinvent the wheel
[ it's like they went out of their way to reinvent the wheel
LOL - German engineers. How's that iDrive in the M?
don't have it - ours is an 05, manual trans - didn't want any of that techno nonsense
Last Post by tamathumper
04-11-2011, 11:50 PM
08-29-2009, 04:29 PM
Last Post by caffine
05-05-2009, 12:55 PM
Last Post by EEZATOY
01-20-2008, 10:10 PM
Last Post by Kim
01-05-2008, 09:41 PM
Last Post by Kim
07-17-2007, 09:20 PM
Last Post by edm
07-16-2007, 09:36 PM
