04-21-2013, 07:23 PM
While I'm waiting for someone to answer my latest question on my tail light non-functioning (well, semi-functioning, anyway) problem, I have another one, as I'm simultaneously working on several problems, all of which are kicking my butt. After re-sealing the power steering pump and rack, I have no assist whatsoever (something tells me that's not the way it's supposed to work...). Travis from Rennbay gave me a few things to check, including one that I'm not sure is correct. He told me to remove the cap from the power steering fluid reservoir while the engine is running to see if I can see fluid flow, as this would be an indication if the pump is pushing fluid to the rack. I did that, and I don't, but I also did the same on my daughter's 04 BMW 325i, and I can't see any indication of fluid flow in the reservoir on that car, either, so I'm not convinced this is something we'd normally expect to see. Next time you fire up your engine, could somebody please remove the PS reservoir cap and see if you can see any indication of flow of the fluid? Thanks.
(This post was last modified: 04-21-2013, 07:23 PM by Cloud9...68.)
