Threads: 25
There may be to much fluid in the tank to see movement, you could try sucking some out and looking again.
When you first filled it did the fluid go down, meaning did you have to top it off again? (it should have)
Also did it make a whine at first that stopped after turning the wheel back and forth several times?
Rick
(This post was last modified: 04-21-2013, 07:41 PM by
968rz.)
Threads: 17
If you rev the car with the lid off you should be able to see the fluid moving , lower fluid level wil make it easier to see .
It is not a common problem , but i had air trapped in the sytem once blokking the fluid flow (not the 968 ) after loosning the lines and making a huge mess with the ATF oil , it worked fine .
volvo V70D5 Black
Porsche 968 amethyst
Threads: 19
I had mine completely off when I did the engine work. I followed the manual, or something I read somewhere; filled the res. ran the wheels back and forth, just shy of full lock. Repeated this until the res. took no more fluid. This process seemed to get most if not all the air out. I had to top the res. off a couple of weeks later, but I also have a crush washer on one of the lines that is weeping, so the top up may have just been from the small leak.
'92 Midnight Blue 968 Coupe
Threads: 15
My car has had heavier-than-normal steering ever since I've owned it. As I've stated elsewhere, I've replaced everything in my steering system, except the pump, which I re-sealed, trying to cure this, with no improvement. Maybe it's always had the vanes in the ps pump facing the wrong direction - perhaps from a rebuild by some previous owner. I'm going to be a little pissed if my entire problem all along has been nothing but those damn little vanes!
On the other hand, I'm going to be VERY happy if, when I open the pump and switch the vanes around, it finally solves the problem!
-Austin
'94 Black/Tan Coupe
Threads: 15
I chickened out of that job and got an AutoZone rack. No leaks anywhere so far. Wish I could say the same about the engine...
-Austin
'94 Black/Tan Coupe
