Threads: 24
My AC was cooling fine and then all of a suden, right before going to the Porsche 250, it decides to die on me. I think it's a relay somewhere, but not sure. Here are the symptoms:
- The light on the AC switch on the dash illuminates
- The secondary fan kicks in and it blows harder
- There seems to be no drag on the engine, so I assume the compressor is not engaging
- The air does not cool down at all when going from vent to AC
- Usually, you can hear a relay, maybe in the dash, kicking in when keeping the temp in the car - it's not engaging
How can I check the relay under the hood? What else should I try? Thnaks!
-Bart
P.S. The P250 was pretty good - at least it didn't get rained out.
Late 94 968. 6 Spd, Black/Black, 17" Cups. Lowered & Koni[color="#FFA500"][/color]'ed. <i> 217k miles and clicking away more every day</i>
Could be for sale if you are interested in a good high mileage car - PM me.
Threads: 24
Thanks Cab, that looks like an excellent guide. I'll do those today, I hope.
Threads: 4
Check Heater control valve(HCV) above Oil filter is closing/opening when A/C is on and off. you can check this visually. I'm interested to know what was wrong. please post the findings.
94 Guards Red/Cashmere Coupe, 6 Speed, 17" Wheels
Threads: 24
I know about the HCV issue. Some people reccommend staying with the plastic Porsche part and replacing it every XXXXX miles. That's probably what I will do.
Dumb question here, but is that not the low pressure line right there at the drier? I think it is just low of freon because everything electrical seems to be okay (fuse OK & relay responds as it should). I bought a can a R134a, but the fitting doesn't attach to mine. Maybe that is the high pressure one there.
Haven't downloaded the manual yet, but I will search for some info. Thanks for any help.
-Bart
Threads: 24
Aw hell, that's what I was afraid of. I've, obviously, never done much AC work. I couldn't tell squat from my sight glass, really. I do have the can with gage, so I was gonna check that before I put any in.
Thanks again, cab.
-Bart
Threads: 224
Having the same prob. Im on vacation now but will follow the steps above to try an solve my AC prob. Just wanted to drop in and thank everyone for their help. Its HOT over here on the East Coast!
Threads: 24
Aha! I think mine doesn't have a sight glass, either. It has a allen head set screw in the top of the drier, I think. If it is a sight glass is is terribly hard to see anything.
Threads: 137
Most sight glasses are gunked up and need to be cleaned off. Personally I've never seen a drier without a sight glass.
Shine a BRIGHT light on top of the thing and wipe with a rag w/wd-40 sprayed on it and wipe,wipe,wipe and it should show up...
But, I've been wrong before! <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 51
Correct me if I am wrong here, but if you are low enough to trip the low pressure swith on the system, the compressor in not going to run. How are you going to see any activity through the sight glass if the system is not working???
I had the system in my 944S quit on me and I hooked up a can of 134a to the low end with the car running and the A/C switch on. At first the compessor would not come on, but after the can of gas brought the pressure up to the point of bypassing the switch, it kicked on and sucked the can dry. System worked after that.
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
