After my first adventures (see here
http://www.968forums.com/topic/14834-nee...ring-asap/) I took the car to the shop.
They were able to take out the old heater core in less than an hour (including glove box removal), and the replacement slid right in. But now they have encountered a road block: The cannot get the clips (944.572.287.00, part 7) that connect and press the tubes together back on. The found matching o-rings (even thinner than the original ones), but no luck in getting the heater core hooked up.
Did anyone here do this job before, and did they encounter the same problem? What was the solution?
Or in general, any thoughts and what else they might try? Could the o-rings still be wrong (maybe they are a different material)?
Any help or suggestions would be greatly appreciated!
