05-05-2009, 07:33 PM
Hello folks,
This is follow up from my post a couple of weeks ago where I found both a coolant leak and an auto trans fluid leak. http://www.968forums.com/index.php?showtopic=7302
I found the coolant leak (sometimes I have to let the car sit before I get enough separation anxiety and then am willing to go at it). Here is a pic of the leak.
Here is the plug after I removed what was left.
Apparently the drain plug on the lower left of the radiator broke in half. I have never removed it or touched it. The other half is still in the hole, I can see the blue stub in there. So the question is:
1. Can I just push the broken part back into the hole?
2. The hole is rather odd, appears to be a rubber material, is that the bottom part of the radiator?
3. If I have to remove it, any suggestions? I may be able to drill a small hole into it, but there is a risk I will push it in anyway when I apply pressure with a drill bit. How long is that stub? It is recessed in the hole about 2-4 mm, so there is no chance to get a grip on it.
4. Does anybody know is this plug is the same as on the 944 for example, or some other car? If so, then I may be able to drive tomorrow and find one around town. The PET shows part number 944 106 353 01.
Ok, so how did this break? A few weeks ago, I did hit a shopping center ramp fairly hard in a tight situation (even bent my Grieman grille which I have to straighten). But I don't think it was hard enough to cause impact on the radiator items.
And the big worry / question: you may recall that after I brought the car home it continued a slow leak. That is very consistent with the broken plug, since it just weeped for days, even today.
But the big worry is that my ATF fluid is just dripping out of the reservoir in the rear. This has never happened before. The car was level the whole time. So I am very worried that there is some damage in the radiator which I think contains a chamber for the coolant and a chamber to heat the ATF. I'd be grateful for ideas, does anybody know the internal architecture of the radiator chambers? Could there be an internal crack? I figure the next step is to pull the connections for the ATF, first the one on the passenger side above the lower radiator hose and see what is inside. And then on the driver's side as well. Again, the only reason I can think of for the ATF to just start to overflow is that coolant from the front is pushing it out the rear -- very odd, a bit scary.
To illustrate why I need help, here is a trivia picture for all. What is wrong with this picture?
Yeah, found when I inspected today. (It was me, been there since last summer [img]style_emoticons/<#EMO_DIR#>/ohmy.gif[/img] ).
Thanks all.
Roland
Thanks all.
Roland
