I think this is the last set of items that I need to post, running the wiring.
To recap, the following was routed:
- 4 AWG wire from the battery to the back to power the amp (now I'm thinking 8 AWG would of been fine, but 4 is better)
- 9 Conductor cable (trade name "Speedwire") to route the 4 pairs of speaker wires from the head unit, and one extra wire for switched 12 VDC to switch the amp on/off
- (6) 14 AWG wires from the output of the amp to the speakers, (3) left, (3) right. These had to be routed through the doors for the four door speakers.
I made up the 9 conductor and 2 door speaker wires, put tape on certain sections, the ones that will be exposed most. I ran them in the rocker on the passenger side, so on the other side of the rocker steel from the AWG 4 power wire. The purpose of this was to shield it from potential interference and alternator whine, which I succeeded, no noise in the system.
I had to use an electrical snake to run these wires, as it is hard to run it through the rocker panel, I was happy with everything when I was done.
Speedwire (blue wire) and two sets of speaker wires for the door:
Using an electrical snake to get the cable run (which was taped with hockey tape) through the rocker:
Here is the door jamb, I did not tape it all the way.
And here is it running behind the fuel filler neck, I was troubleshooting my fuel smell at the same time, that's why it is torn apart:
