+ a gazillion on the suck part.... [img]style_emoticons/<#EMO_DIR#>/sad.gif[/img]
I'd definitely try removing the interior handle and pulling on the cable with some vise grips or something. I would also try and push on the exterior (near the keyed handle part) while someone on the inside actuates the handle or pulls on the cable.
You won't be able to remove the bottom map pocket speaker thingy as there are screws on the bottom of it which will not (most likely) be accessible with the seat in the way. If you can remove the map pocket speaker thingy, it is practically solid fiberboard behind it- no real access to the door internals unless you cut the fiberboard. Really the only things you can remove from the inside of the door when the door is closed are the handle bezel and window switch bezel. Everything else, as far as I can remember, needs the door to be open for total access/removal.
If those fail, call Jeff Clark at Sunset Porsche in Oregon. Tell him your situation and ask if he can speak with a tech about it and if there are any tricks. I did this with a different issue and sure enough there was a "trick" that got me "unstuck". Then you can buy whatever repair parts you need from Jeff. Win-win!
Not shilling for Jeff/Sunset, but he has helped me out of a significant jam before and has always been wonderful to deal with....
I feel some of your pain as my driver's door wouldn't open from the outside (inside no problem). The end result is the lever that is actuated by the black plastic handle on the outside of the door was actually broken to pieces. So now, I consider myself an expert door panel remover (probably done it close to 30 times total between my first 944, my 944S2, my first 968, and now the 968 cab) and I also know how to remove the door handle completely if I ever need to change the handle gaskets. Not sure if I should be happy about that or miserable for having to learn how! Unfortunately, I have yet to put the door handle back into/on the door, so we'll see just how good I am at reinstallation!!!!!! Let's just say there ain't a lot of room up in that corner! [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
Good luck and keep us posted!
