Odyssey battery mouting kit
Did anyone try mounting kits for Odyssey 680 lightweight battery listed in Performance catalog and on www.automotion.com site? The kit has a kill switch option and, unlike the Portable Power Systems' battery box, comes with all hardware and does not require any drilling. However, it is listed as available for 911s/Boxsters/Cayennes and not for 968. I wonder if someone tried to install it on 968/944?
Andrey
1994 Iris Blue cab, Weltmeister chip, KLA brace, K&N, Victoracers, Odyssey battery, Iridium plugs
1989 944 Turbo, Victoracers, Odyssey battery, Fastest Time of Day at Metro NY autoX out of 60 cars
Looks like a Rennline mount: Rennline battery mount
This is it and aready ordered. Thanks!
Are there any concerns with using the Odyssey battery? (Cranking power, durability, etc.)?
I've got one in my track car, and I love it...weighs about 11 lbs!
We made our own mounting kit, though.
Jason
My track toy runs a 968 motor and uses an Odyssey battery -- but I have it mounted using a custom bracket (made from aluminum heating duct brackets from a hardware store...) If you live in cold climate, then I would worry about cranking power. I have killed the battery over 1.5 hour of stop/go traffic, because at constant idle, you are running a slight power deficit -- but then how often are you stuck in traffic for more than one hour?
03-01-2014, 12:35 PM
Last Post by SILVY968
02-22-2009, 04:15 PM
Last Post by Cloud9...68
07-03-2006, 04:06 PM
