03-01-2020, 11:33 PM
Was finally able to take on my "odometer isn't working" issue today, and as others have found, was able to remove cluster without removing steering wheel. I'd purchased a set of gears from www.odometergears.com awhile ago, and just was able to do the work today.
I think I might win the award for "most destroyed gear" - the small gear was totally intact and undamaged, but the larger gear on rear that meshes with the actual gear that turns the odometer was completely obliterated.
Just for reference - the part labeled "Back" below is what that blue mush in my above picture should look like :
I suspect VDO may of made the original gear out of PlayDoh.
Fragments of the destroyed gear were scattered throughout each cog of the odometer gear :
I managed to clean them all out with a pick, brush, q-tips and compressed air :
After reassembly, odometer appears to work OK (for the first time since I bought the car).
Worst part of the whole job, in my opinion, was the removal and re-attachment of the three ribbon connectors behind the cluster. The rest was tedious, but not difficult.
Happy to help anyone else who is taking on this effort - the rest of the threads here were useful, but many of the pictures were no longer working, so figured I'd add some from my work today.
(This post was last modified: 03-01-2020, 11:39 PM by Velocity.)
