04-09-2010, 05:56 AM
Hi guys,
Today I decided to finally fix my odometer. After reading a few posts on the forum, I ordered myself a 15 tooth gear (luckily the right one) and then proceeded to remove the instrument cluster.
Wow...what a pain in the neck!! Is it just me or is it really, really cramped in there! Maybe it has to do with the fact that I didn't remove the steering wheel. In any event, I don't even know how I managed to disconnect the three main cables as well as the twin-bolted plugs and finally pull out the cluster. This seemed to take forever!
Once out, replacing the actual gear was very easy, especially when following the tutorial found on this forum.
Then I put it all back together...and that's when my problems began.
Basically, the odometer and trip meter now work perfectly, but the three main bulbs that light up the instrument cluster when you turn on the headlights just wont turn on! I did the prudent thing and just connected everything up first before putting the whole dashboard back together, so I can clearly see that the three bulbs are just dead! This is also odd because the watch - triggered by the same headlights switch - works fine (dimmer and all).
Furthermore, my airbag light has gone on. This wasn't the case before I opened up the instrument cluster.
Any ideas?
cheers,
milton
Any ideas?
cheers,
milton
Sold
