05-11-2007, 12:20 PM
some of you got to see this at hershey, though it was pretty hard to see under the car
when brey-krause came out with their lower suspension brace, i was immediately impressed with 2 things:
1 - the concept, especially for cabs - the lower suspension perches are weak in both models, and flex there is noticeable - their brace resolved that
2 - the beauty of the unit itself - the thing is a work of art
however, upon closer inspection, a couple of things popped up - the brackets didn't fit well (though they came up wiht a solution to that with pete's help) - however, to install it meant you needed to get an alignment - i had already had a half dozen alignments at that point, and did not relish the idea of another one - besides, this brought the cost up from the nearly $300 they wanted for the unit, to nearly $500 after an alignment - i just had to figure out something else, if only on principle
so, i went to work coming up with a less elegant but every bit as effective solution - i was willing to sacrifice a bit of aesthetics if it meant i could get the performance - after all, it's under the car
this unit does not require an alignment at all, is pre-load adjustable, can be installed in minutes, and is so effective that it shocked me upon the first drive - i was backing out of my driveway, had the right rear wheel in the street, and the front wheels still in the driveway - i stepped out of the car to see if my splitter was going to clear the driveway, and as i was walking back to the car, i looked at the left rear wheel and saw daylight under there! - the chassis was now so stiff that the wheel was in the air - i knew that the big hoop chassis brace had removed 60% of the chassis flex, but this had removed all but the last bits of the rest of it - i was stunned - then i went for a drive - absolutely amazing - all of the wiggles and twitches were gone - the car was incredibly solid
in hershey, pete took it for a short drive - his comment was "it feels like a well-sorted coupe" - that said a lot to me
i still have to work out the pricing - some of the parts are to be automated to reduce cost, but it will be much less than the brey-krause, and will not require an alignment (as long as you carefully follow the instructions) - it's a kit with a lot of parts, but it's pretty simple
i am guaging interest for the first production run, so if you want one, please email me via the button here (no PMs please - the box fills too fast)
the unit will be available exclusively through RS Barn
here is a shot of it installed:
(This post was last modified: 10-07-2011, 01:10 PM by flash.)
