New carpet
I decided to start a new topic on my carpet replacement. Some of the things already discussed from another post was that I am in touch with Bob of 928Leathershop. Bob and I live very close to one another so the other day I brrought the 968 over to his shop and we discussed replacing the carpet. Since as far as I know, 968 carpet is not specifically available, he will consider using my carpet as the template. hopefully, it will become available to everyone, but that is up to Bob.
As in the other post, I felt that German velour that he used was the best of his carpet choices for my car. It is a plush cut pile with backing. It is fairly flexible and should contour nicely. More difficult contours will have to be stiched at Bob's shop. He felt the carpet was fairly close to the 944.
I decided to leave off the door pockets as most of the screw holes were badly damaged. I will fashion new fiberglass surrounds and cover them with carpet and new speaker grills.
The speakers were old so they have been removed. I will install some new ones before replacing the carpet.
As for carpet removal, two words: BE PREPARED!
Be prepared for a tough job requiring many hours. In most places the carpet is held fast by a super sticky flexible glue. If the carpet should fall back into place or get folded on itself, you will have to unstick it all over again.
Besides that, it is otherwise a simple procedure.
My order for the coupe(have a good sized container for all the clips and screws):
1) remove door pockets (just screws all around)
2) remove all floormats and vacuum
3) slide front seats all the way back and remove front allen screws. slide seats all the way forward and remove all the back allen screws. Tilt seats toward center armrest and unplug the electrical connections. remove front seats from car. Remove the center console change box, ash tray and screws holding center console. remove stick shift knob, mine came off by pulling stright up. remove all this stuff
4) remove trunk carpet mat (heavy one with foam) you will expose the clips which retain the lower portion of the rear seat vinyl. Flat tipped screw driver to drive them towards the rear bumper.
5) with patience and great effort, seperate the front bottom edge of the l;ower portion of the rear seat from the sheet metal and floor carpet. Only the front edge is really glued well. A large flat crowbar allows constant upward pressure while you get a thin blade knife in the cut the glue. Takes time. Don' cut the seat. Once the front edge is free, the bottom portion lifts up and out.
6) you have now exposed the mount screws for the fold down seats(middle ones under center cover). Before taking them out, it may be easier to remove the rear seat covering carpet. Go slowly as there are many clips holding the carpet as well as the vinyl covers.
7) with the rear seat out, you can pop the screw covers for the rear side panels. there are also several hidden connectors so go slowly. you will have to remove the seat belt and door surrounds as well.
8) once the rear side panels are out, you can remove the rear side carpet.
9) now the whole rear end is done and you can start on the front. remove the black plastic threshold covers first (front to rear, metal clips again)
10) slowly remove front corner carpet pieces and the the three main front and mid carpet sections.
good time to check wiring and speakers and such. may want to plan ahead for sound deadening material if you don't mind the weight.
one more pic
Dropped off my old carpet to Bob at the 928leathershop this evening. Bob and talked about the carpets, new leather cover for the center console tray, new leather for the seats. Hopefully, he will be able to make the appropriate patterns and have the carpet set done in a few weeks.
Decided to go with Black German velour. Looked real nice with white car and tan leather seats.
I think the glue used to fix my carpet in place is not typical and may have been an early production thing. Seems like much glue was wasted and I have seen other 968's where there is not nearly as much.
Every 968 I've seen has tons of the glue from hell, they definitely did not skimp on it.
Nice work rad!
With a few more details on your pics (where the bolts were etc) this would be a nice DIY. You said be prepared. How long did all of that take?
Maybe you could add your location to your profile? The beautiful mountains in the background tell me CO, or maybe Flagstaff??
Location of avatar is CO...Aspen...from PO(good sales pics).
Im on the far far west side of Detroit. Will be adding more pics but the nuts and bolts thing is really straight forward. Only maybe twenty-thirty screws/bolts....
Challenge is slowly peeling up the carpet. I took altogether about 6-8 hours of glue cutting and peeling. Bob says he has seen this before. We had to separate a piece in his shop and it took two of us pulling and one spare hand to cut the glue strands...
Strong Sh+t....
Anyway, I guess it will be a few weeks before I hear anything regarding the carpet template. Will keep U posted...
[quote name='xrad' post='49402' date='Mar 17 2008, 05:29 PM']Location of avatar is CO...Aspen...from PO(good sales pics).[/quote]
The white looks great against the snow capped mountains. Good luck with your restoration. Will be worth it all in the end. Another 968 gets a new life!
I'll follow this carefully - new carpet could be on my list.
As a step in this direction, I just replaced my trunk carpet with new OEM. Got the item from Sunset - none available in the US, only 3 left in Germany (I guess that makes 2 now). So, if you have cashmere, and are thinking about it, now's probably a good time. Not inexpensive, but...this is, after all, a Porsche. <img src="/forum/images/smilies/968/tongue.gif" class="smilie" alt="" />
Hopefully, if Bob at 928leathershop gets my carpet together and there is interest, he says he may market the carpet set. This will likely include floor mats and full trunk mat (and the heavy carpeted undermat with supports for the trunk wells)
still waiting for things to come together......
...and I'm still following the progress.
Received Fatmat today. 50sqft kit. Comes with roller and knife. Pretty heavy and very sticky. Will prep and install next week before carpet.
Nothing new on carpet.
Just received word today from 928leathershop that a low cost mock-up of the carpet pattern is complete. Will test fit Friday morning.
Mock -up made from inexpensive carpet to test pattern. From this pattern , I hope to get a very nice carpet set.
Nice to see that progress is being made.
well, it could have been much faster in my opinion.
a few early pics..
This is just a preliminary set cut from old carpet. Will eventually be fitted directly to car . Left and right rear side pieces likely going to be two seperate pieces. This is domestice pile. But, I prefer German velour. Domestic Feels pretty good to the touch. All edges were sewn for this mock set. Really nice work overall.
Of course, 928leathershop has gone through some effort to get this made up and the work is being done locally(Detroit). Since these are hand made, there will always be some variation in fit. I can't speak for them, but If there is enough interest, 928leathershop would likely consider a run. I know some of you are following this thread...
I have no financial interest in the production of these carpets. And I would say the work so far is very good.
Anyone else seriously interested in new 968 carpets?
Where did he get the patterns?
These would only work for the Coupe right?
for the patterns, I refer you to the pics in my post number 1 in this thread. The patterns are from my old carpet.
For the coupe.....
I don't know how different the sets are in regards to the rear wheelwell area. Obviously trunks differ.. From front firewall to front of rear wheelwell probably same
I'm interested in interior carpeting - not trunk. So, the fact that my car is a cab is, I believe, irrelevant.
[quote name='Anchorman' post='52155' date='May 9 2008, 05:45 AM']I'm interested in interior carpeting - not trunk. So, the fact that my car is a cab is, I believe, irrelevant.[/quote]
Check http://www.autoatlanta.com/purchase.html
They have carpet sets on sale for under $200
Smokiemon: No way these are as nice for 200$...maybe they mean floor mats???
Last Post by dccr55
02-16-2020, 01:51 PM
Last Post by BOB968
06-06-2017, 03:17 PM
Last Post by kmckmc
11-12-2016, 08:32 AM
Last Post by SILVY968
08-29-2011, 01:53 AM
Last Post by durtkillon
11-18-2010, 09:56 PM
