[quote name='earossi' post='36345' date='Jun 2 2007, 08:52 PM']If you do not see any coolant on the ground and there is no coolant in the oil, and you have determined that the system needs to be topped off every couple of weeks, my vote is that you have blown head gasket. I minor seepage would not produce any noticeable white smoke; and, since it appears to be a very slight leak, I think that white smoke would be hard to see.
To make a more educated guess, have the radiator cap tested and then put a pressure test on the cooling system. If you have a slight head gasket leak, your system will not hold pressure. But, the rules are simple: there are only about three ways to loose coolant (with a seal leaks, or a hose, or your reservoir overflows). Secondly, you can have an internal leak in the oil/water cooler, which produces a milky looking oil which is coolant and oil attempting to mix. Thirdly, you have to have coolant leaking into the combusion chamber, which is usually indicative of a failed head gasket.
Good luck.[/quote]
Question though, If I do have a blown head gasket, even if minor, shouldn't I see signs of oil and coolant starting to mix? At the rate I am losing coolant, I'm not sure if a minor blown head gasket is the cause. I do not see any white smoke out of my exhaust. Not even on start up after the car has sat over night. If I did have some leakage into the combustion chamber, wouldn't the engine also run rough for a little when the car is first started up? I have not had a pressure test done on the cooling system yet. The system does seem to hold its pressure since there is still some pressure in the system even after several hours of the car sitting and the cap does seem to hold pressure in the overflow tank. I forgot to state that I only drive the car once or twice a week. It is a weekend car. I guess I need to over the engine bay again looking for a visible leak. I hope it is a simple old seal and not a head gasket.
[quote name='S_Cal968' post='36346' date='Jun 2 2007, 09:13 PM']To add... If the coolant is getting into the cylinders, a possible indicator is an unusual deposit on the spark plug(s). If your coolant is green, the deposit will be a greenish-white. A spark plug electrode should be a light tan.
I occasionally have to add coolant and found a couple of my hoses seeping. The factory pinch clamps don't hold as well as the adjustable type.[/quote]
Thanks...I will pull the plugs to see what condition they are.
