Looking for some specific engine specifications
Hi gang -
For a little project I'm doing, I was looking for the following specs on the 968. I'm putting together a big, comprehensive 968 Specs sheet that I will post when I'm done. Can anyone help with the following? Thanks!
-Mirror
Fuel injector maximum flow rate
Throttle Body diameter
Block deck height
Bore Spacing
Mean Connecting Rod Length
Combustion chamber volume
Reverse gear ratios for both manual and tiptronic
Curb weight, Automatic Transmission
Weight distribution, Automatic Trans.
Front Spring rate (standard and M030)
Rear Torsion bar rate (standard and M030)
Brake master cylinder piston diameter
Reverse gear ratios for both manual and tiptronic:
MT: 38:11 = 3.455
AT: 2.882
Brake master cylinder piston diameter:
23.81/20.64 mm
Curb weight, Automatic Transmission:
Coupe: 3152 lbs
Cab: 3306 lbs
these are from the tech specs manual
the weights posted in the 94 owners manual are 3086 and 3240
the 93 tech specs book lists them as 3086 and 3240 as well
the workshop manual lists the hardtop at 3020
Last Post by dlearl476
08-13-2021, 01:11 AM
08-12-2019, 08:37 PM
02-02-2019, 04:41 PM
Last Post by banditsc
04-02-2017, 05:39 PM
Last Post by MLB
01-05-2016, 03:13 AM
Last Post by cosimo
01-04-2015, 03:39 PM
