Instrument Cluster lighting / warning light
Is your flashing handbrake warning the big ! In the center or the actual handbrake warning on the temp/fuel gauge?
Current: 1994 968 Coupe, 1987 944S, 2004 VW GTI 1.8T, H-D XR1200
Previous Porsches: 2000 986S, 1974 914 2.0 Blue, 1974 914 2.0 Yellow, 1970 914 1.7, 1985 928S
Previous non-Porsche favorites: 1974 Early Bronco, 1975 Cosworth Vega, 1977 Trans Am 6.6L, 1973 Karmann Ghia, 1983 Supra (turbocharged)
Quote:There are three bulbs illuminating the dash. I replaced mine with LED and it's fantastic. Much brighter.
When you replaced the 3 bulbs, with LED did it require a new socket as well, or did the bulb fit into the OEM socket? Can you tell me the LED bulb number and brand please? Would putting in only 2, say the two outside ones, make it less bright or would the bulb light not reach across enough?
William, I used this.
http://www.walmart.com/ip/Sylvania-168-1...b/29029256
First I did what you suggested, LED on the outside and regular in the middle but it looked weird with the orange color in the middle so now it's all 3 with LED. I kept the OEM sockets and inserted the new bulbs into them.
thanks for the photo, great I can read it. so I can recommend to my mechanic thank you JTD
<sup>I just had my mechanic change the bulbs to the LED suggested above. All I can say is WOW</sup>
<sup>With the new bulbs I can see everything. The markings are pure white in color, and while it is brighter it is not at all distracting. It took me a couple of night time driving to get use to it </sup>
So I changed out my odometer gear, put it all back together, and the lights in the cluster don't work.  Every other light on the dash works and the alarm/notification lights on the cluster work but not the regular lights that light up the gauges.  Anyone know which of the three plugs in the back is the most likely culprit so I can try with my fingers from underneath before tearing it all apart again?
Must be an age thing (your age not the car) as I put the LED  in and I love them but then I am 67 and night vision aint what it used to be..
Last Post by unknown4u
08-31-2008, 03:28 PM
Last Post by xrad
08-09-2008, 07:17 PM
Last Post by SILVY968
02-07-2006, 12:42 AM
