Threads: 22
Flash, I have a reinstallation CD for Windows XP home edition. Let me know if this will do.
Carl
1992, Guards Red, Coupe, 6 spd., LSD, Drilled frt. rotors,
Threads: 31
[quote name='flash' post='66666' date='Feb 7 2009, 02:10 PM']does anybody have a windows xp disk? i need to overwrite my 2000 laptop to xp so i can run a couple of programs in the garage[/quote]
do you have a cd burner and software that can burn an iso image? I can put the disk up for you to download and tell you where to get software to burn it if your 2000 machine has a cd burner.
If not I can send you a disk.
Threads: 44
What brand laptop is it? I can send you the OEM disk (depending on the brand) and you may not need to use a product key. It depends if your model is included in the OEM license for that brand.
Threads: 31
I'll fedex you a disc Monday. I'll see if I have any memory for it but might be tough to find the memory since I am moving my office this weekend and everything is packed. Going from 18,000 sq ft to 10,000 sq ft is tough even after filling several 40 ft dumpsters. email me an address again
(This post was last modified: 02-08-2009, 10:05 AM by
Mark.)
