[quote name='unknown4u' post='33182' date='Mar 25 2007, 03:50 AM']What you have to do is the following steps, Anchorman
Step 1: Download the software:
Step 2: Buy the interface at Andy's shop
Step 3: Place the jumper on the outside pins.
Step 4: Cut the led of the interface marked as D4.
Step 5: Buy a female female cable 9 oins for the comport.
Step 6: Run windows 2000
Step 7: Connect the leds to the right holes in the 19 pins connector.
Step 8: Turn on the ignition
Step 9: Select the airbag option. Read the codes and clear the codes.
Step 10: Look at the dashboard and you wil have a big smile. Lights are out.
The complete topic has all the FAQ what you have to do if something doesn't work out.
Good luck Anchorman,
Ritchie[/quote]
When one of you buy this very interesting tool and actually use it, I'm sure that there will be many interested 968ers since this could be a great tool to add to one's box. Offhand, it sounds a bit tedious to use. There's a similar product (I hear) being made for 928s but it's closer to $500...and more functional I think.
Harvey
