Threads: 147
Ryobi 3000 PSI pressure washer... I saw it at home depot a few months ago and decided to take my Kracher gas 2500psi pressure washer back. The Ryobi has a smaller storage footprint, higher PSI and a built in removable wash bucket that sucks the soapy water. I like the layout of the PW better too. This thing is great for your all around pressure washing needs but it seems to be designed for that car guy in mind.
A couple of notes.
- I like the quick disconnects on the hose it makes storing the hose easier.
- The hose is thicker then any of the other pressure washers I have used.
- there are two areas with comparments to place odds and ends one has a hinge door. The other has a grate so the water can flow through.
- The bucket is very handy and makes washe the car with a sponge easy.
-The wand has its place down a long shaft it just does not hang from a hook like other units.
-The upper part of the unit swings around for compact storage.
BTW it works great! Big thumbs up. :thumbup:
http://www.ryobitools.com/index.php/outd...l/ry80030/
Black 03' Turbo X50
Black 05' Denali
