When changing pads, DO:
1) Make sure the retainer clip actually is caught under the spring plate (spent a day at the track wondering why rotor wear was so strange - DOH!)
2) Loosen and re-tighten the two little phillips screws that hold the rotor onto the hub and give it a spin to ensure it is centered. It may just be from racing, but my fronts have started to "wander" from their correct centered position twice now.
When changing pads, DON'T:
1) Get into the habit of "filing" pads to make them fit. If the spring plates are corroded and gunked up, it really pays to remove them. Porsche sells replacement kits with spring plate and screws. The screws can be the devil to get out. But, once cleaned and refitted... pads slide in like a dream.
