06-20-2013, 06:12 PM
Here's one I'm sure has never been asked before - could someone please place a straight edge across the surface of one of their headlights, and measure the distance between the headlight glass at the edge, and the bottom of the straight edge? I think it's in the neighborhood of 3/8" to 1/2". I'm going to take a crack at creating my own lexan covers for my fixed headlight conversion, and I'd like to curve them to match the curvature of the original headlights. I've seen plenty of conversions which used flat lexan covers, and this approach looks very crude and home-made to me. Thanks.
Also, I'm open to any suggestions as to how to do this. My plan is to make a "frame" that exactly matches the outer edge of the cover (minus the width of the frame, which will be about 1/2"), attach this frame to a piece of plywood, place the cover on the frame, place a weight in the center of the cover, and place the assembly in the oven at a temperature where lexan (polycarbonate, actually) will soften, until it sags to a depth that roughly matches the radius of curvature of the headlight. I did a trial run of this awhile back, and while it turned out suprisingly well for a first try, I discovered that the lexan cover follows every imperfection in the frame that it's resting on during the softening/sagging process. So, I'm not sure how I will be able to build a frame that's "perfect" enough to not have any imperfections transfer into the lexan.
