have you gone too far with your car when....?
have you gone too far with modifying your car when others interpret something they feel as something else?
here's the story:
everybody knows i've been nuts about modifying the car, and have gone to great lengths to stiffen things up - i took up the challenge of tightening up the chassis, because there were those who said a cab would never be stiff - ok - i solved that one - after measuring the car on a 4 pin layout, with a 1G load of about 750lbs per corner, i found .065" of chassis flex in stock form - after the mods, i have .011" of flex - that's an 83% reduction in flex - not bad so far
that was great until my last round of suspension mods
i pulled out the koni yellow sport struts that so many people are running, as well as the 300# springs and rubber strut bearings, and installed some koni dual adjustable hydraulic struts, 4003 springs and kla monoball strut bearings - i also stuck 600# springs on the dual adjustable hydraulic carrera shocks in the rear
i had already changed out every other rubber bushing in the car to a sealed monoball and such, so there was none of the rubber bushing sloshing anywhere that tends to mask things in stock cars, and give you a very false impression of how the car is doing (you find it out in a hurry on the track)
then i made the mistake of rushing through things and not spending the time tuning it fully, because i was too busy sorting out some last minute problems elsewhere in the car - then i ended up taking it on a fun run like that - no, nothing happened - the front end was bouncing a bit, and there is an imbalance front to rear, but that's it
however, i let a couple of people drive it, and realized afterward that i should have dialed it in first - what was in reality a mismatched front/rear shock tuning, was interpreted as chassis flex - for the record, there is almost no chassis flex - ok - 17% of what was there - by the way, the 2 hardtops i measured had .006" of flex, so we are talking about the difference of a thickness of a business card now - still, a whole lot less than the .375" i had in my race car (which was very competitive by the way)
ok - the bottom line - now that there is no rubber to mask anything, everything shows up very quickly in a sense of uneven movement front to rear - tuning it will be fun, but i am confident that i have nailed the components down, and just need to spend time dialing it in - the hydraulics are much more compliant than the gas, and the ride is very nice - i will be chasing down the last odd twitches and such though, and will probably spend a lot more time than i anticipated doing it
i shudder to think what a formula team goes through to tune their suspension
i am starting to get tired of tuning though, and would like to drive it - sometimes a little goosh is a good thing - had i have left the rubber in the car, i could be driving it instead of tuning it - not nearly as fast in the corners, but possibly jut as pleasing overall nonetheless
the moral of the story - before you run out and buy that hot suspension, be sure you know what you are getting into - you may miss driving that car as you stand there and watch it sit in your garage waiting for you to finish tinkering
Or you could be like me and be out driving the car that is at different heights on all 4 corners since I jacked the suspension up to get it on the tow truck a few months back. That said, I have already adjusted to handling and know how it's going to react in most conditions. Ribs and sternum are almost healed (it doesn't hurt when I drive anymore) so I can get back under it and adjust the damn things.
As you always say
" a slippery slope"
But after all the conversations we have had, I am glad you are "almost there"
Hopefully this will be the final round for at least 6 months...
i think so - i think i really nailed the component choice - definitely think i got the rear - i just really underestimated the front spring rebound on a good dip, and am dancing on compression setting, finding the balance between nice ride and not dipping - the strut mounts make it a bit tougher - not sure i like them or not - very positive feel, but a VERY POSITIVE FEEL, if you know what i mean
lol - i'm just not letting anybody else drive it until i'm done - i knew better - i knew it wasn't ready - i tend to let people drive it though, and i was too much in the moment - but, i don't want to be the guy making excuses for my car, so i need to spend this week finishing it off
"I know what I was feelin,
But what was I thinkin"
So if I've read right and based on your numbers - in stock form the coupe is 10 times stiffer than the cab? (.065 vs .006)
I think the more appropriate interpretation of this data is to say that the coupe showed about 10% of the deflection that the cab showed. Whether that's the same as "10 times stiffer" defends on how large the "stiffness scale" is. I wonder how much deflection other cars show?
lol - yeah - pretty easy to jump to that kind of a conclusion
that's also static load - there is a whole set of torsional rigidity tests that i don't have the equipment for - it doesn't continue to flex though - the structure stops it dead in its tracks at a point not far from that dimension
it's very easy to tell how much it flexes though - look at the door latches - they recieve all of the impact and load from any flex - you can see it at the door gaps too - it just isn't much, even in stock trim - after the braces, it's almost nothing - you really can't feel it at all in a rubber bushing car
the odd "good news" is that one thing the cab does that the hardtop doesn't is absorb more of the impact from bigger and heavier wheels - the chassis takes up some of the load - same could be said of a stiffer suspension - of course this leads you down the path of chasing where that load goes and what to do with it, which is how i came up with the braces to begin with - round and round
i have one more round of chassis mods in mind - when i am done, the cab will be stiffer than the hardtop, with a lower center of gravity - pretty easy really - porsche already did half the work for me with their reinforcement on the cab - there is a LOT of extra steel in there that just hasn't been taken advantage of fully - not sure why i didn't think of it before - i must be slipping - it will add another 25lbs or so though, so i am trying to figure out where that is going to come from first
lol - it truly never ends
I will end when you let it!
Just put the wrenches down and step away from the vehicle sir!
roflmao - i seriously need to do that - the last mod may well wait until the race car (since it will be a cab as well)
i think it's time for an intervention
[quote name='RS Barn' post='47253' date='Feb 11 2008, 07:22 AM']"I know what I was feelin,
But what was I thinkin"[/quote]
<img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" />
Sean - San Francisco
Time to take his wrenches away. Well maybe it wouldn't be right to take them away he needs to atleast maintain the car. Take the wrenches away and replaced them with cheap Chinese versions..
11-29-2023, 10:05 PM
Last Post by Kim
06-22-2020, 02:14 PM
Last Post by Bulti
11-07-2016, 01:49 AM
