Threads: 177
As the hatch seal gasket gets older the pins will end up being progressively too long (ie the hatch seal will compress more with age, pushing the head too far down into the locking mechanism in the latch pieces attached to the car). To keep the hatch from rattling you can either shorten the pins a bit or replace the seal. For me, once the new seal was installed, the pins were then too short and I had to lengthen them a bit. But do it just a bit at a time. Be sure to loosen the nut on the threaded part where it screws into the body first to allow the pin to then turn. It also helps to loosen the two bolts holding the two locking mechanisms just a bit to allow them to wiggle - if you carefully close and then open the hatch this should position the latches perfect with respect to the pins. Then tighten them down.
Kim Strong, Nova Scotia
2022 Mustang Mach-E
Threads: 51
I can relate - I've been working on one of my hatch pins on and off for years now. :-) I even tried to remove the mounting plate holding the pin - two socket bolts as I recall - but the plate is glued to the hatch due to a little bit of oozing hatch glass sealant from the factory. Go figure. The hatch is adjusted well - it just bothers me that I can't turn that one bolt. Sooner or later the hatch glass will get re-done and I guess that will be time time to really fix it!
