Bottom line up front, my hatch glass shattered into a thousand pieces and I need to replace it. For years I've been watching the top edge of the glass separate from the frame. I tried the DIY repair of cleaning out along top edge and regluing with urethane a couple times, it would hold for a while then just get worse. The hatch would barely open due to the uneven glass bond racking the frame, the only thing keep water out was a long strip of clear tape that I schlepped on there out of desperation.
Several glass shops looked at it and said no way are we touching that. Finally found one that would, but when they had the glass almost all the way off, it shattered as they were cutting through the last bit of old urethane on the lower corner. Bummer but not really a surprise. They are having a hard time finding a replacement glass, although a polycarbonate replacement is available.
So has anyone replaced their hatch glass, and if so with what?
