gears indicator light - question for those with tiptronics
On my tip, when the shifter is switched to "manual" gear mode , the only way I can get the little light ( which indicates which gear you're in ) to come on is to turn on at least the first setting on the lights knob , so parking lights need to be on.. at the very least. Otherwise, no little red light on the display letting you know which gear is in driving in daylight , lol. Does anyone else here have this electrical gremlin mystery on their car ?
Dan,
I've also been looking through the site for a solution to this problem. I have a '92 Tiptronic. I can't get my dash cluster to display any gear indication in either manual or auto mode unless the lights are on. We're you able to solve this?
trent
Trent
1992 968 Coupe Tiptronic
I did not look for a solution because it just does not bother me sufficiently to spend a ton of money on this ( I'd have to have a mechanic look into chasing the possible culprit and then fix it , which in light of our cars gremlins could add up to hundreds and hundreds if not more than a thousand + ) Not worth the trouble . It functions perfectly fine, I can shift by feel , so having the light is just a novelty item and when it annoys me or I really need to test certain limits in each gear to satisfy my curiosity , I'll just turn on the parking lights :-)
Dan,
My problem was a fuse. The fuse that runs the clock was blown. Once I replaced it, the indicator light came on with the ingnition switch regardless of tip or manual mode. Weird.
Trent
Trent
Interesting, but I assume with that fuse blown the clock would also not function.. ? Mine works just fine . Still thinking it's an ignition glitch ; the PO said he had a few issues with the ignition ( I can't remember what it was now but nothing essential - door chime or some other minor stuff like that ) so it's possible it still has a gremlin or a contact problem somewhere in there.
ds - yours is absolutely related to the ignition switch.  there is a component in it that is deliberately connected, as leaving it connected resulted in a dead battery overnight.  unfortunately it will almost certainly require replacing the switch assembly, as the actual problem is internal.
Your correct in that my clock wasn't working. I rarely look at it and went to update it for daylight savings time. I noticed it was not working, checked the fuse, found it blown, replaced it and all is good with the clock and gear indicator. I'm sorry your fix sounds more complicated.
Trent
09-13-2025, 07:36 PM
05-31-2023, 04:27 PM
Last Post by MLB
11-07-2017, 11:39 PM
