04-06-2021, 04:25 PM
I pulled the appropriate blown fuse, replaced it, and got another blown fuse when turning on the interior light. What had I done that might have caused this? My passenger side window dropped with the failure of the spot welds that hold the guidance system. I removed the door panel, window assembly and repaired this. My exterior temperate instrument failed years ago. I replaced it with a battery operated Chinese version, running the wire with sensor into and through the interior wheel housing. This didn't work because it picked up road heat. I then learned that the original sensor was in the passenger side mirror. Since I already had the door panel off, I removed the cover at the bottom inside of the A pillar, pulled loose the ribbed rubber housing that carries the wiring from the A pillar into the front of the passenger side door and up to the base of the mirror. I than ran the temperature instrument wire with bulb up to the underside of the mirror. Fearing that I would break something if I rotated the mirror forward to access the removal bolt (it resisted turning), I simply stuck the señsor up into the wiring opening at the bottom of the mirror and left it there. I then carefully replaced the ribbed rubber tubing between the A pillar and door and called it a day. I don't know if that had anything to do with the interior light failure, and ditto the rear compartment light. Any way to trouble shoot this without simply blowing more fuses? Is it likely I caused an electrical short when I installed the temperature sensor wire and bulb, meaning is there a wire involved in that wiring packet that could short the interior light?
