Fidanza Flywheel
Does anyone know anything about this flywheel? If you were going to have to replace your flywheel, what would you use?
flywheel
I had the RSBarn lightweight flywheel installed a couple of months back, fantastic upgrade. Also went with a softer pressure plate, car feels completely different in a good way. I now have a stock clutch and pressure plate with about 1500 miles on them up in the parts bin in my garage for the wife's car when hers needs replacing
[quote name='Mark' post='52274' date='May 10 2008, 09:07 PM']I had the RSBarn lightweight flywheel installed a couple of months back, fantastic upgrade. Also went with a softer pressure plate, car feels completely different in a good way. I now have a stock clutch and pressure plate with about 1500 miles on them up in the parts bin in my garage for the wife's car when hers needs replacing[/quote]
Hey Mark, I appreciate the feedback. I'm going to have the pinion bearing replaced and figured I might as wel
take care of everything I know will need doing. My indy resurfaced the flywheel when the clutch exploded a couple of years ago. It's never been quite right since. Feels like I'm driving a 67 Camaro when driving in traffic. The car is wasting away in my garage because its just too iritating to drive in Atlanta.
If you want a Fidanza. Then get one of the RS barn ones. They are the CORRECT weight..
The one you linked to is too light for our cars.
The weight makes a big difference in drivability + engine longevity....
Dave W.
95 - 968 Sport with Cup 1,s + 2,s ...
[quote name='Big Dave' post='52286' date='May 11 2008, 05:23 AM']If you want a Fidanza. Then get one of the RS barn ones. They are the CORRECT weight..
The weight makes a big difference in drivability + engine longevity....[/quote]
Thanks for the feedback guys!
I would also add that if you are going to do the pinion Bearing you might consider installing LSD...it would only add the cost of the part.
Regards,
[quote name='94SilverCab' post='52292' date='May 11 2008, 06:47 AM']I would also add that if you are going to do the pinion Bearing you might considr installing LSD...it would only add the cost of the part.
Regards,
Jay[/quote]
That is darn good advice, its a very significant "while you're in there" upgrade. Whether you choose a Torsen limited slip differential or the OEM Porsche version, its hard to go wrong with that upgrade.
-Mirror
that's exactly what i did - i was chasing down what the "porsche mechanic" thought was a rattle in the transaxle that he swore was a bad bearing or something - we swapped out every bearing in there - TWICE - same rattle - turned out to be the result of the aluminum flywheel
but......i got the LSD installed in the process, and i have a fresh box, so, i guess in the end it was money well spent
i went with the GT torque bias unit - very happy with it
I also have the RS Barn flywheel, very happy with it. As noted, the weight is correct - as per the motorsport item. I personally would not like to go for much lighter. With Pete's, the revs drop a littlemore quickly than previously, plus you need to be marginally more aware of it when going from a standing start. Neither at all severe, and after a couple of days becomes second nature. If you went much lighter, these effects would be pronounced and make the car rather unfriendly for day to day use.
Upshot is a much more responsive car, i should have gone for it a long time ago.
JP
i agree - i have the 12lb fidanza unit, and while i love it, this car is a toy, and i am also very used to driving with a super light flywheel, having done it for 25 years in a different car - however, i would not like this in a commuter car
the 17lb rs barn unit is much more civilized
I know the clutch is pretty easy to do on the 968, but how about the flywheel? Do you need to pull the tranny and back off the torque tube like a 944?
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Flywheel adds almost no time. (its right behind the clutch).
and no, the trans does not come out
however, VERY important that you balance the flywheel and pressure plate - count on being down for 3 days unless you have a machinist at the ready
[quote name='flash' post='52387' date='May 12 2008, 04:25 PM']and no, the trans does not come out
however, VERY important that you balance the flywheel and pressure plate - count on being down for 3 days unless you have a machinist at the ready[/quote]
Have them balanced as an assmebly.
yes, as well as individually - that is the correct procedure - you do the flywheel and pressure plate individually - then, you put them together and verify, correct, and clock them
Last Post by kwikt
11-22-2020, 04:31 PM
Last Post by JTP
08-21-2015, 11:03 PM
Last Post by Bulti
05-29-2015, 11:54 AM
Last Post by roccap
04-26-2011, 06:53 PM
