dual mass flywheel
I'm replacing my clutch after a dramatic failure of the friction disk.
How much rotational movement would you expect on a DMF when you try and push it with normal finger pressure?
TIA
paul
I happen to have mine out at the moment (I'm planning on replacing it with a single-mass). Are you saying you can get the two pieces of your DMF to move against each other just from finger pressure? I'll check mine when I get home tonight, and let you know if I can do the same (I didn't think this was possible on a healthy DMF, but I could be dead wrong about this).
I need to look at our notes
While in car holding/jamming flywheel gear , and putting torque wrench on pressure plate bolts we could get 10-15mm rotation on dmf with new-good and 25-35mm on expired dmf
How much torque did you apply for that?
Paul
Last Post by kwikt
11-22-2020, 04:31 PM
Last Post by JTP
08-21-2015, 11:03 PM
Last Post by Bulti
05-29-2015, 11:54 AM
12-01-2008, 06:18 PM
