08-09-2009, 09:20 PM
Yesterday took our 95 Cab to a test only Smog station. About a year ago, the catalytic converter failed, plugging the exhaust. The shop installed a German aftermarket CAT, recommended by the local Porsche parts supplier. The failed Cat was NOT OEM, having been replaced by a previous owner/dealer in Florida; according to Carfax our car had been through two dealer leases in Florida. Still the car passed the two previous smog tests with the wrong Cat. This time the test facility not only tested emissions but as part of their visual they checked the Catalytic converter number against the ones approved for this car and didn't get a match. The previous Cat replacement had removed the flanges in the exhaust and welded the cat in-line. Last year the shop replaced with the same. I suspect that the correct part number is for a cat converter with flanges while the same cat converter without the flanges might be unlisted.
I feel like I'm stuck as I'm now on record as having a tampered exhaust system, modified catalytic converter, wrong catalytic converter.
If only the OEM part passes state approval I don't have the wherewithall to go that route. Since this was originally a Florida car, would it have had a different Cat than a California Car?
This incident went a long way to ruining the weekend. Maybe I can get a waiver or register the car as planned non-operational. For those of you in California, I apologize if I have alarmed you with this story. I may have found one of the few Test Only smog check stations that is this thorough; it was also a Gold Shield repair station (that may have been my mistake).
-sp4149
-sp4149
