02-14-2011, 02:12 AM
My lower balance shaft cover is pretty well covered in oil, so I plan to re-seal it. But I'm wondering if there's anything else I need to do as far as the sealing of the lower balance shaft to prevent the leak from recurring. When I replaced the belts three years ago, I replaced the front seals of both balance shafts. Both were bone dry (as is the rest of the front of my engine), so I know that isn't the source of my leak. There's a seal in the back of the balance shaft, part number 99970187540, which is about six bucks, but I get the impression it isn't replaced very often.
So my question are: Should I go ahead and replace this rear seal while I have the balance shaft cover off? If so, what does it take to get this seal out? Does the whole balance shaft have to come out? If so, doesn't that basically mean the removal of the engine, because there isn't enough room in front of the engine to remove the balance shaft with the engine still in the car, right? Or is it possible to just loosen the balance shaft and slide it forward a few inches to allow removal of this rear seal?
By the way, I learned something new this weekend. I had assumed the balance shaft cover piece had a gasket between it and the engine, and that I would have to replace this gasket. It turns out the balance shaft covers are sealed so the block with Loctite 574 flange sealant, which is available from Walmart.com for $16.07 for a 50 ml tube, which should be plenty. You can also buy the stuff at your friendly neighborhood Porsche dealer (disguised, of course), but my dealer wanter $53 for a small bottle <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />.
