Threads: 24
About 475 miles (2.5 months) ago, Beverly Hills Porsche did an oil change on my 968. Today, in traffic, the Engine Oil light came on, along with the big red exclamation point. Checked several times, hot and cold, with a dip-stick; engine oil is fine. Added a quart of Mobil 1 Synthetic, just to be safe. Engine oil pressure responds the way it normally does. Everything seems fine.
The oil sensor was changed about 4 years (~5,000 miles) ago. Looks like this one's gone south too. :\
I'll get it in ASAP for that, but in the meantime, is there a way to reset the error code / clear the big red ! ?
Bone-stock '94 968 Cabriolet, '95 Wrangler SE 4.0L, '06 Ducati Multistrada 620 Dark
Practicing law and hacking code in Los Angeles, California (southbay, Miracle Mile, westside...)
Threads: 24
[quote name='flash' date='Oct 7 2005, 10:18 PM']the oil level was fine and then you added a quart???
eeek! i've heard that very bad things happen from that
[right][post="10917"]<{POST_SNAPBACK}>[/post][/right][/quote]
Like?
I only put maybe 5 miles on since then (from the Auto Zone at La Cienega and Pico, back to Park La Brea).
Can drain a bit tomorrow before running it again.
What's the potential damage?
Threads: 24
[quote name='flash' date='Oct 7 2005, 11:14 PM']blown seals and such
[right][post="10920"]<{POST_SNAPBACK}>[/post][/right][/quote]
Think it'll be safe to creep down about 2 miles to a Jiffy Lube type place tomorrow mornin'? (I've been driving with the RPMs at or below 2200, until the engine mounts get replaced. Taking her out once a week or so, just to keep moving parts moving...)
Threads: 24
Closing the loop... I decided to chance it (my luck's been good lately) and nursed it (try 5th gear at 35 mph) a mile to the Jiffy Lube at La Brea and Melrose, at 7am. Had them do a full oil change, Mobil 1 Synthetic; $60, better safe than sorry. (Discounted since my filter, being 500 miles old, didn't need swapping.) Then took her on an easy 120 mile loop, all freeway, 6th gear, 2500 rpm, 65mph. Nothing adverse as of yet, knock on wood. Even the stupid Check Engine light went out (thinking I need to try cleaning the contacts on my knock sensors, before dropping the change to replace them, since it's so intermittent), though not the Engine Oil nor the exclamation point. :\
Well, she's back under cover for another couple of weeks... I'll sort out more then.
Threads: 177
"in the meantime, is there a way to reset the error code / clear the big red ! ?"
Disconnect the battery for at least 10 minutes.
Kim Strong, Nova Scotia
2022 Mustang Mach-E
