12-15-2011, 11:50 AM
I recently purchased a '92 968 that had been sitting unused for 11 years (20k miles). After performing the usual set of maintenance procedures, the car started and ran beautifully. I installed a new 7 year battery but after sitting for a few days, the battery was dead. I recharged the battery, disconnected the negative cable, attached a circuit volt tester between the negative cable and negative post on the battery and found a drain. By disconnecting fuses, one at a time, I found the interior/hood/luggage light fuse was where the drain was coming from. From there I found a bad door switch. I thought the problem was solved.
A long preamble to my question. Now, when I attached the circuit tester from the negative cable to the negative post of the battery, I get a brief flash of the bulb that immediately goes out. It does this every time I connect the circuit tester. Almost like there is still a residual drain, but not enough to light the circuit tester. If I leave the circuit tester connected, the light stays off. Any thoughts?
Sold
