[quote name='flash' post='36027' date='May 26 2007, 10:29 AM']yup -
to give you an idea of the difference, as a result of my recent oil hose mishap, i purged the system, put in new redline oil, disconnected the coil and pulled the plugs so that i could prime the system
since in had the plugs out, i figured i would change them to fresh ones - also, as long as they were out i figured i would go ahead and do a compression check
my readings went UP over the last test by about 4% - i am now hovering at about 200 across the board
some might immediately jump to the oil change as the cause - however, i went to a LIGHTER oil, and there really wasn't a chance for it to seat on the rings anyway
it seems that the timing and overlap of the valves is quickly affected by slight timing adjustments - more compression equals more power - doing fast math, that 4% represents 9.6hp - it's funny, because i said it felt like maybe 7-8 - looks like my buttometer is pretty well calibrated - i haven't tested it yet to confirm any of that, but it is noticeable
i am looking forward to driving the car now - the added power of the timing adjustment was cool, but, according to redline, the new lighter oil should help too, as well as drop the oil temps a bit[/quote]
So what was the cost to having the timing dialed in using indicators and who did the work?
