Threads: 16
What tires work well for both DE and autoX - i.e., warm up quickly and maintain grip on track? My track car is a 1989 944 Turbo with 16" rims.
Racing slicks are the best, but they are not in my plan (or budget) as I have no spare storage space/trailer and drive to the track. I love Kumho Victoracers V700s for autoX as they warm up instantly and stick like glue. Unfortunately, they got all mushy and lost grip after just two DE days. I kept tire pressure constant, so it seems like the tires just don't like the track day heat cycles.
What do you guys use for DE or autoX? Any thoughts on a good comporomise for both events?
Andre
1994 Iris Blue cab, Weltmeister chip, KLA brace, K&N, Victoracers, Odyssey battery, Iridium plugs
1989 944 Turbo, Victoracers, Odyssey battery, Fastest Time of Day at Metro NY autoX out of 60 cars
Threads: 64
[quote name='Andre' post='46120' date='Jan 21 2008, 08:38 PM']What tires work well for both DE and autoX - i.e., warm up quickly and maintain grip on track? My track car is a 1989 944 Turbo with 16" rims.
Andre[/quote]
Avon Tech RAs are very good for both, and tend to last. They're not exactly slicks, as they have two channels in them. You should be seeing better wear out of the Victos.
Chris
1992 Polar Silver Cab - tip, keyless entry, subwoofer, koni adjustables, clear bra (show and touring car)
2006 Marine Blue Cayenne Turbo S - 520HP of fun!
1973 911 RSR Clone Race Car - 2000lb of fun!
Threads: 12
Andre -- how many heat cycles did you have before the DE? I ask because I wonder if it the number of heat cycles and not the track day itself that killed the tires. I was planning on using the Kuhmos on the track. Now I'll think about it. Thanks.
1993 Black coupe @ 100K
LWFW + Chip
M030 Sway bars with Delrin from RSBarn
Southboro, MA
Threads: 16
Thanks, I will definitely check out the Toyos!
My Victoracers did have two autoX days and ~500mi street driving prior to the DE, so they had a few cycles on them already. Erik, you are right - I probably overdrove tires in corners at Lime Rock, back on gas too soon...
Andre
Threads: 18
+1 on the toyo's Andre <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
93 midnight blue cab
03 kawasaki zx6rr
03 k2500 duramax
83 944
66 volkswagon squareback
Threads: 10
Another option now from Toyo is the R888 tire that has been available overseas for some time. It is listed with specs. on the Toyo website, so I assume it would be available at dealers now or at least soon. It comes in standard sizes for 968 wheels, is claimed to have as good ro beter performance as RA-1's, and is UTOG rated for 100 wear. I'd be interested to try a set for my next track tires.
Cheers,
Stephen G.
Moscow, Idaho
'93 Guards Red coupe, 6-speed, LSD, 17's, chip, strut bar, M030 sways, airbox mod,
Threads: 16
Thanks for the advice! Toyos for this season- it's decided. It seems that Tirerack.com doesn't carry Toyos. Does anyone know a good source for them on-line?
Andre
