Threads: 49
My 92 has started vibrating, and I suspect one of the balance shafts is out of synch.
Does anyone have a step by step guide for checking them?
It may be the motor mounts as they are a few years old, but before I just start swapping parts, I want to check the shafts.
It's a very small vibration, not like an old panhead Harley going uphill on a tank of bad gas, more like a high-frequency buzz that I feel through the pedals.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 4
beware, i felt the same, later i heard a clicking noise, and balance shaft belt was stripped off the teeth on half of its length, and when the first remaining tooth hit the sprocket on the balance shaft, , it made a click.. pull out airbox, and put down the covers, and if you find anything wrong with the BS belt, just cut it and pull it out, car can run without it, and you will not risk damaging your engine by timing belt vs balance belt interference. do it NOW
1992 968 Targa with M030+M220
1989 951 M030 M220
If in doubt, FLAT OUT .
Threads: 49
Thanks for the input, I will check the belts this weekend, but they were just replaced, along with the rollers, about 500 miles ago. If the shafts are set properly, I suspect I will be replacing the mounts. I have to figure out how to measure them to see if they are collapsed, but I understand there is a thread on here that tells how to do it.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
