Another stereo install
Last month I upgraded my stereo and took some pics of the process. I replaced my head unit
with a Kenwood EZ-500. It has a line in connection for my ipod. Plus many other features.
Link: http://www.crutchfield.com/S-DcaoAtCvnbm/c....asp?i=113EZ500
I used 968bills tweeter mod to install my tweeters. That worked great thanks for the info.
I order to install my 5 1/4" drivers in the stock door locations I had to make a spacer
to move the driver away from the back of the door panel so it would fit. I also had to trim
some of the stock speaker grill and a little part of carpeted off the bottom trim piece so
the driver would not hit it.
The front speakers are NOS SoundStream SPL series. 2ohm
I had to remove the covers from the cross over so it would fit under the speaker enclosure.
I had some extra HK 6 1/2" drivers laying around that I to made spacers for so they would not
hit the body. I mounted those in the stock rear location with the cross over and tweeters.
For power I wired in a NOS SoundStream 180w 4 channel amp.
(I have always been a fan SoundStream< but their new stuff sux as it is now made in tiwain)
Sound is amazing! I trimmed the amp so I could turn the volume all the up with no distortion.
Sound is crystal clear @85mph with roof off and windows down.
Now I just have to install 1 more amp with a sub. I was thinking of going with the KLA unit
or the on at www.JAGENG.com
I will probably go the KLA route as I don’t want to see it.
Patrick
I see you got at the rear speakers (with out removing the window?) was this a P.I.A. or not. my rt rear is out and I havent messed with getting at it.
Rick
[quote name='968rz' date='Jul 3 2006, 09:28 AM']I see you got at the rear speakers (with out removing the window?) was this a P.I.A. or not. my rt rear is out and I havent messed with getting at it.
[right][post="23635"]<{POST_SNAPBACK}>[/post][/right][/quote]
Back window is different from the 944. Just remove the plastic trim around the window (snaps in place),pull the trim from the door sill, and remove 2 screw.
20 mins. top per side.
patrick
Last Post by Westy
10-29-2016, 11:48 AM
10-30-2013, 09:52 PM
04-11-2011, 09:35 PM
01-15-2011, 08:59 PM
08-29-2009, 04:29 PM
Last Post by ebarone968
08-28-2009, 04:43 PM
